Hello everyone, I am studying the influence of the boundary properties of the building on the indoor temperature, but I have not been able to find the interface between the butterfly and the HB material properties, so I have a doubt, whether I can use the HB material properties to associate with the butterfly to make a CFD distributionCalculation?
For this you can use either of the following recipes.
http://hydrashare.github.io/hydra/viewer?owner=chriswmackey&fork=hydra_2&id=Indoor_PMV_Comfort&slide=0&scale=1.0000000000000013&offset=-45.962549372044464,-17.411623021145942
http://hydrashare.github.io/hydra/viewer?owner=chriswmackey&fork=hydra_2&id=Indoor_Adaptive_Comfort&slide=0&scale=1&offset=0,0
In order to couple this with Butterfly, you’need to derive wind velocity from Butterfly and then supply them to the windSpeed_ input on the microclimate components in either of the recipes.
