Question about using the district steam component. I have attached it on its own plant loop with a heat exchanger going to a hot water loop. Despite the changing the fluid on the loop to steam, I am getting a fatal error where the nodes themselves are requesting water. How can this be changed?
** Severe ** Existing Fluid type for node, incorrect for request. Node=NODE 44
** ~~~ ** Existing Fluid type=Steam, Requested Fluid Type=Water
** Severe ** Existing Fluid type for node, incorrect for request. Node=NODE 46
** Severe ** Existing Fluid type for node, incorrect for request. Node=NODE 47
