I’ve just uninstalled all LB/HB and installed the latest LB version (1.7.26) and noticed many of the HB tabs were not there compared to the old HB set up I had. In particular, the ‘HB Run Energy Simulation’ component is missing. Does this no longer exist or do I need to install from somewhere else if it’s not included in the latest LB update?
Thanks, but HB-E only contains HB annual and peak loads, and the OS app, not the ‘HB Run Energy Simulation’ one. I assume that’s been ditched so we just can use the OS one to do more or less the same thing.
Note that the HB Model to OSM component has run_ set to 2, this keeps the openstudio simulation from running and only writes the *.idf and *.osm files.
then using the HB Run IDF component, you can run your EP simulation.
the picture’s file is here run_energy_plus.gh (24.9 KB)
