Does the sDA component work?
Hi, I’m doing a DA and sDA analysis, but I’m worried that this tool isn’t working properly and is giving poor results. Is this my fault? Has anyone tested it properly and can say it works properly? I’m using version 1.10. ![image]
Finally, if I connect the mesh to sDA, I get slightly higher values. What if I connect the mesh to sDA?
Grazie
Hi @Lucky,
It looks like an image failed to upload?
When connecting a mesh the value for each sensor is weighted by the corresponding mesh face area. Without a mesh every sensor is weighted the same.
