@Nimafo Hi, I guess I am doing something wrong! I have a rotated sky matrix 180 degrees but the north sign is still showing the default. When I connect the 180 degrees to the north sign then it shows the correct direction (south). So I guess by connecting 180 degrees to sky matrix, it is working properly and the north becomes south.
@Nimafo@AbrahamYezioro, Yes I get it and it changes the north sign in the viewport. But to be actually effective, I need to connect it to the sky matrix because the other component only shows the north sign. So when I connect it to the north sign and it shows the degree that I want, I just connect to the sky matrix and it will be working properly, right?
I’m not sure I’m getting your question right, but connect the same input you are connecting to the Sky mtx to the north input of the ladybug north component to visualize it, so that you won’t confuse the direction that your model is using.
The north direction can also be defined by a number between 0 and 360 that represents the degrees off from the Y-axis. It seems that in most components the angle is interpreted as anticlockwise, but in the PV components (Ladybug Photovoltaics Surface and Ladybug Sunpath Shading) it is specifically defined as a clockwise angle. Is this right, or am I making a mistake?
