Domestic hot water, flow rate if assigning HWS to HB Rooms
Hello!
When I assign the Hot Water System in HB to certain HB rooms only, can I use the flow rate already provided from the program, e.g. for midrise apartments, or do I need to adjust this flow rate based on my expected number of faucets, tubs, etc?
I am asking because I am not sure how the change in the square footage (since the flow rate is given on a per m2 basis) might affect this.
Thanks!
Hi @elenialex, I recommend sharing a sample file so others can help you effectively. See here for more best practices: Ladybug Tools Forum Guidelines - faq - Ladybug Tools | Forum
