Dragonfly cannot be used
  1. Solution exception:The URBANopt simulation failed to run.
    No results were found at:
    C:\Users\13467\simulation\unnamed\run\honeybee_scenario
    Top level ::CompositeIO is deprecated, require ‘multipart/post’ and use Multipart::Post::CompositeReadIO instead!
    Top level ::Parts is deprecated, require ‘multipart/post’ and use Multipart::Post::Parts instead!
    C:/URBANopt-cli-0.11.1/gems/ruby/2.7.0/gems/urbanopt-cli-0.11.1/lib/uo_cli.rb:25: warning: already initialized constant URBANopt::CLI::UrbanOptCLI::COMMAND_MAP
    C:/URBANopt-cli-0.11.1/gems/ruby/2.7.0/gems/urbanopt-cli-0.11.1/lib/uo_cli.rb:25: warning: previous definition of COMMAND_MAP was here
    Invalid command, please run uo --help for a list of available commands
Hi @LIAO
The version of the URBANopt installed on your machine is not compatible with the required your version of LadyBug tools bundle.
I recommend to see the compatibility matrix of the versions and make sure all items are matched. (it is better to go for the latest versions)
