Dragonfly-Envimet simulation error
Hi there!
I’m trying to run my first simulation with dragonfly-envimet, but in the final step this is what i get.
“envimet4_console.exe” is not recognized as internal or external command, executable program or a batch file
Any idea of the problem?
Thank you!
Hi @sipicco,
have you download latest version from https://github.com/chriswmackey/Dragonfly? And are you using Envimet 4.4.4.?
Regards,
Antonello
Hi @AntonelloDiNunzio , yeah, that was a version problem, i mixed two different releases of the plug in.
Thanks for the help!
Same problem again…i downloaded the latest version of Dragonfly (0.0.03 JAN_23_2020), and i’m using Envimet 4.4.4
Strange fact is that it worked pefectly until one hour ago, than i ran another simulation in another file and the “envimet4_console.exe is not recognized as internal or external command, executable program or a batch file" popped out again.
Even stranger fact is that now also re-running the simulation on the first file i was working on causes the same problem :man_facepalming:
Hi @sipicco,
I will improve the batch with some istructions to handle “cd” error with comments and “go to” instructions soon. Basically you had a cd error.
Where is located your Envimet4.4.4 folder? In C unit or D unit? Do you have Envimet in both units?
When you open the second file, have you changed or refreshed the path where Envimet software is?
I would like to replicate the issue, I have an idea but I need to try.
Advices:
  1. Use “False button” instead normal toggle button.
  2. Give a Different name to Simulation files when you want to run many of them.
Regards,
Antonello
Hi @AntonelloDiNunzio , thanks for the reply
The Envimet 4.4.4 folder is located only in the C unit.
Yes, when i opened the second file i refreshed its location (i was still using the 4.4.3 version of envimet for that file, so i uploaded the directory to use the 4.4.4 version).
I’m using the Button component instead of standard toggle now
Behaviour so far with the first (A) file and the second (B) file:
-Running simulation in B works
-Running simulation in A doens’t work
-Trying to run simulation in A (failing) makes the next simulation in B fail too
-Having both .gh files opened at the same time will make simulation in B fail, even without running the simulation in A
It’s a bit confusing but that’s what’s happening :thinking:
I’ll attach a link to download the B file, since it seems to be the problematic one
Ok, mysterious problem and mysterious “solution”
I duplicated the .3dm file associated with the .gh (file B), moved it to another directory (in the C unit) and now it works :thinking:
Still not working if i put the .3dm file in any directory on the D unit, even with a different name
Maybe the .3dm file needs to be in the same unit of the envimet folder (?)
final (hopefully) edit
i “solved” the issue copying the ENVImet 444 folder on the D unit and everything looks fine by now
Thanks for the help :slight_smile:
Hi @sipicco,
thanks for your summary and solution. I will analyze it.
I have just added an improved batch to run simulations and two new components for an important feature: read receptor results.
Receptor results!
You can find this version here, but try it only when you have finished your analysis :).
As I told you, Rhino does not recognize all radical changes in components when you open file with old plugin versions. Than You have to replace them manually at some point.
Antonello
