I’ve been looking through the code for various Dragonfly and Ladybug components, and I’ve run into a few lines of code that I think might have been meant to be written differently. Apologies if I am mistaken.
The first occurs in the code behind the DF Dragonfly component, in the Vegetation class’s init method. Line 1880 initializes self._s_trees = is_trees, but there are no getter and setter methods for the property _s_trees, only for is_trees. I’m wondering if self._s_trees was meant to be self.is_trees?
The second is also in the DF Dragonfly code, in the VegetationPar class’s setter method for self.vegetation_start_month. On line 2115, self._vegetation_start_month is always set to 0 regardless of whether or not the user entered a valid vegetation start month. Should there be an else before line 2115 like there is for the vegetation_end_month setter?
The third is in the code supporting the DF Run UWG component, in the set_uwg_input method. On line 170, if DFCity.vegetation_parameters.vegetation_start_month == 0, uwg.vegEnd = vegEnd, but according to the logic used in lines 166-167, shouldn’t uwg.vegEnd be initialized to the epw default value only if the user entered a 0 for DFCity.vegetation_parameters.vegetation_end_month (check for end month instead of start month)?
The fourth is in the Ladybug_Ladybug component’s Preparation class, in the epwLocation method. Should the second to last line of the method reading epwfile.close actually read epwfile.close()?
Lastly, I just had a quick question. I noticed that in the code for the DF Run UWG component, in the autocalcStartEndVegetation method, on line 94, vegEnd is initialized to 12. However, vegStart is not initialized to any value. This means that if we’re looking at weather data for an area for which no month’s average hourly temperature is above 10 degrees Celsius, returning an uninitialized vegStart value would raise an error? I ask this because I’m unsure whether or not we can trust that every location for which epw files exist definitely have average hourly temperature greater than 10 for at least one month.
Thanks so much!
