I want to use my rhino geometry to create an ENVI-MET model. I have Rhino 6 and ladybug (legacy) properly installed and I have ENVI-MET 4.4.4 installed. I’ve downloaded the entire github repository to C:\Users%USERNAME%\Appdata\Roaming\McNeel\Rhinoceros\6.0\scripts. If I try to run the DF installer component I am getting a windows error (Win32Exception).
Underneath it says
line 185, …
line 73. …
line 128, …
I think your error is with Dragonfly[+] because “DF installer” is part of it.
Instead Envimet components are part of Dragonfly Legacy. You can:
download dragonfly from here: https://github.com/chriswmackey/Dragonfly
– run installer.gh and set its component to True.
– this will be install Dragonfly Legacy with envimet components
There is also a beta version of envimet components for Dragonfly Legacy that contains some new components to read envimet results:
If I download Dragonfly from https://github.com/chriswmackey/Dragonfly and run the installer.gh I get exactly the same… (it says I need to download the installation packet from food4rhino).
