I am new to both Dragonfly/Ladybug and Envimet and I am trying to follow this video as a tutorial. However, the envimet location function is not working and therefore, the viewGrid too is not functioning. What am I doing wrong?
This was solved. Had to use an older version of Ladybug legacy. However,
now I am struggling with DF-legacy Read Envimet Library component, which seems to have some source code issue - see screenshot.
Does it mean I have to use an older version of DF-legacy too? The video uses 0.0.03.
Hi @SuNa, Dragonfly legacy version is not upgraded. You can use this new version called Morpho
Hello, were you able to solve this issue?
Yes, used DF Legacy but eventually downloaded Morpho for better integration with EnviMet
