Hi @chris and all Ladybuggers
can you give me an answer on this issue:
I have tried to modify the characteristics of the envelope of a new construction, a hypothetical school, considering the “typology envelope” dragonfly component .
I have inserted some random values in all the inputs of this component to verify it they are considered in the output “typology” object. By comparing the related white panel with the default output typology of the BuildingTypology component (see green panel) there are no differences except for the glazing ratio.
Could you explain why?
