Hello.
I’m having problems with the UWG files, I already installed them manually and the problem keeps coming up. Someone knows what might be happening. I include image.
Dragonfly currently only works on Rhino 6.
The Urban Weather Generator (uwg) is not currently installed.
You will not be able to run simulations to account for urban heat island.
Use the Dragonfly installer component to (re)install the uwg or download
the most recent version from here:
and copy the uwg folder to here:
C:\Users\21861\AppData\Roaming\McNeel\Rhinoceros\6.0\scripts\uwg\
- Hi 21861!
Dragonfly is Flying! Vviiiiiiizzz…
Default path is set to: c:\ladybug\
UWGEngine path is set to: None
