Dragonfly_windows error with open dss example
FYI, this is not related to your error but I have not posted the installation instructions for the OpenDSS workflows yet (they are little bit WIP right now but they will still work). In any case, you won’t be able to use the OpenDSS component unless you install OpenDSS.
To install OpenDSS right now, you need to do the following:
  1. Install Python 3.7.9 by downloading the exe from python.org and running it.
  2. Open a terminal and type the following command:
pip install urbanopt-ditto-reader -U
