Hi everyone,
I’m reaching out to ask for your help. I’m trying to use Dragonfly following the technique mentioned in this forum post: Dragonfly Unable to Apply Custom ConstructionSet. However, I’m running into some issues.
Despite changing several materials, I haven’t noticed any difference in the temperature results. I’ve attached my JSON file here.
If anyone could help me figure out what’s going wrong or point out if I’ve made a mistake, I’d greatly appreciPreformatted textate it!
Thank you all so much—this community is the best!
“albveg”: 0.25,
“h_ref”: 150.0,
“glzr”: 0.0,
“latgrss”: 0.5,
“h_wind”: 10.0,
“droad”: 0.5,
“albroof”: 0.7,
“maxnight”: 20,
“dtsim”: 300,
“latfocc”: 0.3,
“blddensity”: 0.44611398898756965,
“albwall”: 0.08,
“sensanth”: 10.0,
“croad”: 1600000.0,
“rurvegcover”: 0.9,
“vegroof”: 0.0,
“nday”: 365,
“h_ubl1”: 1000.0,
“month”: 1,
“autosize”: false,
“schtraffic”: [
[0.2, 0.2, 0.2, 0.2, 0.2, 0.4, 0.7, 0.9, 0.9, 0.6, 0.6, 0.6, 0.6, 0.6, 0.7, 0.8, 0.9, 0.9, 0.8, 0.8, 0.7, 0.3, 0.2, 0.2],
[0.2, 0.2, 0.2, 0.2, 0.2, 0.3, 0.5, 0.5, 0.5, 0.5, 0.5, 0.5, 0.5, 0.5, 0.6, 0.7, 0.7, 0.7, 0.7, 0.5, 0.4, 0.3, 0.2, 0.2],
[0.2, 0.2, 0.2, 0.2, 0.2, 0.3, 0.4, 0.4, 0.4, 0.4, 0.4, 0.4, 0.4, 0.4, 0.4, 0.4, 0.4, 0.4, 0.4, 0.4, 0.3, 0.3, 0.2, 0.2]
“radfequip”: 0.5,
“radfocc”: 0.2,
“windmin”: 1,
“treecover”: 0.0,
“charlength”: 370.60708,
“vertohor”: 2.57669,
“vegend”: 12,
“grasscover”: 0.0,
“c_exch”: 1.0,
“vegstart”: 1,
“type”: “UWG”,
“h_mix”: 0.5,
“h_ubl2”: 80.0,
“lattree”: 0.7,
“day”: 1,
“dtweather”: 3600,
“sensocc”: 100,
“radflight”: 0.7,
“albroad”: 0.1,
“kroad”: 1.0,
“h_obs”: 0.1,
“h_temp”: 10.0,
“c_circ”: 1.2,
“shgc”: 0.4,
“bldheight”: 12.0,
“bld”: [
[“largeoffice”, “new”, 1.0]
“maxday”: 150,
“flr_h”: 3.0,
“zone”: “2A”,
“BEMDef”: {
“building”: {
“floor_height”: 3.0,
“int_heat_night”: 1,
“int_heat_day”: 1,
“int_heat_frad”: 0.1,
“int_heat_flat”: 0.1,
“infil”: 0.75,
“vent”: 0.75,
“glazing_ratio”: 0.4,
“u_value”: 2.0,
“h_heat”: 293,
“h_cool”: 297
“wall”: {
“height”: 3.0,
“materials”: [
“name”: “Pierre_locale”,
“therm”: {
“conductivity”: 1,
“volumetric_heat_capacity”: 1400000,
“thickness”: 0.02
“name”: “Isolation_thermique”,
“therm”: {
“conductivity”: 0.72,
“volumetric_heat_capacity”: 1612800,
“thickness”: 0.5
“name”: “plaster”,
“therm”: {
“thickness”: 0.01
“mass”: {
“materials”: [
“name”: “Beton_masse”,
“therm”: {
“conductivity”: 1.7,
“volumetric_heat_capacity”: 2000000,
“thickness”: 0.2
“roof”: {
“materials”: [
“name”: “Terrasse_traditionnelle”,
“therm”: {
“conductivity”: 0.8,
“volumetric_heat_capacity”: 1800000,
“thickness”: 0.15
“name”: “Isolation_toit”,
“therm”: {
“conductivity”: 0.035,
“volumetric_heat_capacity”: 2500000,
“thickness”: 0.08
