Dumb Sunpath Question: In general, what are the best/easiest methods for only displaying the data mesh every 5th or Nth day?
Hi everybody!
I couldn’t find an obvious solution for this on the forum, so I thought I’d ask while I’m working on it in case someone has an easy method that they can share.
I’m trying to only display the colored meshes for every 5th (or Nth) day so that there will be a gap in between each one, instead of a more or less continuous chain. I’m working on it now, but I thought I’d post this in case anyone has a good way of doing this. Apologies in advance if it’s really simple and obvious :sweat_smile: its been a long week.
Best wishes to all,
Marty
If I understand what you want, you are searching for this.
Nariman
Precisely! But I’m trying to do it in 1.2 and display the dry bulb temp on those days.
  1. Do not connect the analysis periods to a panel before you connect them to the “LB Apply Analysis Period” component.
  2. Use the LB Calculate HOY component to get the HOYs that you need for the sunpath component.
