Duplicate icons ribbon
Hi @BlueMeadows ,
In this case, it’s because the names of those components have changed and, given the way that you updated your LBT plugin, the components with the older names did not get deleted. I recommend running the uninstaller.gh file that comes with the Food4Rhino download and then run the installer.gh again. That should wipe the slate clean and give you a fresh installation.
