I got the following error of duplicated shading surfaces while modeling one detached surface with a hole as a PV surface. I’m not sure if it is caused by the trimmed surface in this case for which EnergyPlus may not be able to process.
> ** Severe ** Shading:Building:Detailed Name, duplicate name=SHDSRF_0_0_6365114D-BF98-4285-BFA5-20DF1E2AF019_0_1_2_3_4_5_6_7
** ~~~ ** …each surface name must not duplicate other surface names (of any type)
** Warning ** GetHTSurfaceData: Surfaces with interface to Ground found but no “Ground Temperatures” were input.
** ~~~ ** Found first in surface=ZONE_0_SRF_0
** ~~~ ** Defaults, constant throughout the year of (18.0) will be used.
** Fatal ** GetSurfaceData: Errors discovered, program terminates.
…Summary of Errors that led to program termination:
… Reference severe error count=7
… Last severe error=Shading:Building:Detailed Name, duplicate name=SHDSRF_0_0_6365114D-BF98-4285-BFA5-20DF1E2AF019_0_1_2_3_4_5_6_7
************* Warning: Node connection errors not checked - most system input has not been read (see previous warning).
************* Fatal error – final processing. Program exited before simulations began. See previous error messages.
It seems this shading surface is duplicated for 7 times, and there are only 3 vertices described for each surface in the IDF file where there should be 8:
The GH file of the simple model is attached here, and appreciate your kind advice.
Thanks.
shading_surf_issue_v002.gh (614.7 KB)
