Hello all. Hi @chris , I am trying to simulate a dynamic glazing with custom schedule having 4 states with PMV comfort recipe of a small shoebox model but its failing. The script is working with normal glazing window but with dynamic window its failing. The error is as below
If you are getting āUnicodeDecodeErrorsā, then the cause is most likely the name that you have specified for one of your objects. Iāll try to check your file when I get the chance but, as a start, you should make sure that all of your schedules, materials and dynamic construction donāt have any non-ASCII characters in them.
Thanks @chris for the quick assist. I have checked the script and itās working with non dynamic window. But still I will have a close look again and please let me know if you could figure out any issue in this script
I recreated the failing simulation on my end and here are the logs: logs.zip (47.6 KB)
(Iām using a zip file as we have to add support for uploading .log files to the forum here).
This is the line that is failing:
⦠and this is the full failure traceback:
2025-02-18 11:49:33 INFO: Failed to run Shortwave MRT Delta map.
2025-02-18 11:49:33 INFO: 'utf-8' codec can't decode byte 0x93 in position 0: invalid start byte
2025-02-18 11:49:33 INFO: Traceback (most recent call last):
2025-02-18 11:49:33 INFO: File "C:\Program Files\ladybug_tools\python\lib\site-packages\ladybug_comfort\cli\map.py", line 593, in shortwave_mrt
2025-02-18 11:49:33 INFO: d_mrt_temps = shortwave_mrt_map(
2025-02-18 11:49:33 INFO: File "C:\Program Files\ladybug_tools\python\lib\site-packages\ladybug_comfort\map\mrt.py", line 89, in shortwave_mrt_map
2025-02-18 11:49:33 INFO: indirect_con = _ill_file_to_data(indirect_con_f, sun_indices, t_step, lp_yr)
2025-02-18 11:49:33 INFO: File "C:\Program Files\ladybug_tools\python\lib\site-packages\ladybug_comfort\map\mrt.py", line 289, in _ill_file_to_data
2025-02-18 11:49:33 INFO: results = binary_to_array(ill_file)
2025-02-18 11:49:33 INFO: File "C:\Program Files\ladybug_tools\python\lib\site-packages\ladybug_comfort\map\_helper.py", line 78, in binary_to_array
2025-02-18 11:49:33 INFO: nrows, ncols, ncomp, line_count, fmt = binary_mtx_dimension(binary_file)
2025-02-18 11:49:33 INFO: File "C:\Program Files\ladybug_tools\python\lib\site-packages\ladybug_comfort\map\_helper.py", line 24, in binary_mtx_dimension
2025-02-18 11:49:33 INFO: first_line = next(inf).rstrip().decode('utf-8')
2025-02-18 11:49:33 INFO: UnicodeDecodeError: 'utf-8' codec can't decode byte 0x93 in position 0: invalid start byte
I can see that the line that is failing is a part of the code that @mikkel added a few months ago to support using binary Radiance files in the comfort recipes. So I think that he is probably best equipped to fix it and I am assigning this issue to him.
If you badly need a simulation like this to succeed right now for your deadline, you can go back to LBT 1.8.0 stable release using the LB Versioner. Iām fairly confident that this simulation should succeed for that version since it was before we started implementing the improvement to support binary radiance files in the comfort recipes.
