Hi Matteo,
Recently I was also doing the dynamic simulation with known shading schedules but I have some questions regarding the XML file and where to put the annual schedule.
I would like to ask how to generate glass with shading in WINDOW 7.7 so I can use it for the simulation, like different window states. For now, I just know after calculating the glass properties WINDOW will automatically generate the XML file but I cannot find the option to add the shading panel.
Regarding the shading state, is it necessary to generate the XML for every shading case?
Can the annual schedule directly be blind states for the sDA or other annual results readers? And what is the format of the schedule, for example, 1 means the shading is on, and 0 means off.
Sorry for bothering you and thank you very much.
Best regards,
Clarence
