I want to add dynamic shading system in the integration of energy simulation in EP and daylight simulation in Daysim, based on zone air temperature. that means that when the zone air temperature is high than my set-point, the blinds will turn on.
The problem is that Daysim doesn’t calculate zone air temperature. So, I need to make a loop with EP, using the zone-air-temperature from EP as a trigger to control the blinds in Daysim.
Does anyone try this? Is my idea feasible?
