Hello everybody,
Does someone of you know if it is possible to assign a schedule to the component “Honeybee_EnergyPlus window shade generator”, or to another component, with different angles for different time steps in order to make the program able to switch between several configurations and make the shading system dynamic? I read that someone suggests to use EMS coding and I was wondering if there is an easier way to do the same by remaining in the grasshopper environment.
Thank you in advance for the availability,
Matteo
