Eddy3D Probes Component Outputting XY Coordinates Instead of Velocity Vector
Hello Ladybug Tools Community,
I am running a multi-objective optimization project using WallaceiX that requires calculating the percentage of points below 5 m/s from an Eddy3D simulation for my wind environment objective function.
I am encountering a persistent issue where the Probes component outputs Point Coordinates instead of the Velocity Vector (U), making the calculation impossible.
  1. The Problem
・ Expected Output: Velocity Vector (U) list (e.g.{-0.5, 2.3, 0.1}) in m/s.
・ Actual Output: Coordinate data (e.g., Vector Length returns large distance values like 807.414).
・ Context: The main simulation (RunSim using 3_SimpleWindAnalysis template) has completed successfully.
  1. Steps I have Taken (Troubleshooting)
I have attempted the following fixes, but the coordinate output persists:
  1. Confirmed Velocity (U) is checked in the Probes component’s right-click menu.
  2. Tried forcing the field name by connecting a Panel with U (and also V and velocity) to the Field input.
  3. Ensured all Probing Points are strictly within the simulation domain.
  4. Replaced the entire Probes component with a new one and rewired all inputs.
  5. Request for Assistance (Impact on Optimization)
This data extraction failure is currently blocking the connection of the wind environment objective to WallaceiX, preventing me from proceeding with the multi-objective optimization.
Given the urgency, could this be a known issue with the Eddy3D version (0.4.15.10) or is there a specific, alternative field name the Probes component requires for this template? Any suggested workaround would be highly appreciated.
Software Versions
・ Rhino: 8.15
・ Eddy3D: 0.4.15.10
Velocity is broken down into coordinate velocity vectors in the OpenFOAM simulation, that is used in Eddy3D. You can calculate the velocity magnitude with additional gh component using:
