I’m doing a cfd simulation and I was wondering if you have any tips/advice to see the meshing. The base view isn’t really efficient to check the meshing near buildings. What i’m looking for is to have a side view like that :
Regards
My advice is to always use paraview (https://www.paraview.org/) to visualize CFD cases. Doing it inside Rhino is really unfeasible after a few million cells.
Regards,
Theodore.
And use wieframe view I guess. Thanks that’s a good advice.
Regards
The surface with edges should do it. You can even get a slice at the area you are interested and visualize the slice with edges.
Yes surface with edge is working fine too not sure what’s the difference with wireframe.
