Electric BaseBoard using IronBug
Hi @MingboPeng,
I’m kind of new to simulating with Honeybee and specifically with IronBug. I made successful tests simulating radiative convective baseboard, but when it comes to the electric baseboard, I got stuck !
I would appreciate if you could help me out solving this.
I attached the .gh file so you can see what i am talking about.
Electric_BASEBOARD.gh (124.9 KB)
Hi @Ardian, I tested your file, everything ran fine on my machine. What is the problem you encountered?
Hi @MingboPeng,
Sorry the simulation ran fine also on mine but, in fact, the issue that I have is that it does not show the consumption results when I use electric baseboards using _resultFileAddress component.
I don’t know if I need to use another component, or is it due to other reason?
Oh, you will need to add the custom output variable for this baseboard:
Output:Variable,*,Baseboard Total Heating Energy, hourly;
and then use Honeybee_Read EP Custom Result to read the results. Note, the default unit from E+ is Joules
Hi @MingboPeng,
OK thanks very much and sorry if it was trivial question as i am new to this.
Hi
how about this workflow in the new honeybee (1.2). I try this for simoutput and got an error. can’t add output as this string in the new version.
Here, there is a Custom Simulation Output:
Thank you a don’t see that.
