I try to simulate the influence of switchable (EC) glazing on the energy budget.
The shading (EC) should be controlled by illuminance on workplane, glare or/and temperature in office.
I’ve done illuminance and glare based simulations in DIVA for Rhino, but in DIVA the control options are limited.
Since I’m a beginner in HB, I could use some help.
Let’s say we have 3 shading states (+ base state)
- When running an Annual Daylight Simulation like this (Glare)
Is the shading controlled on DGP(0.4) or on radiance(W/m²)?
The DGP values in the result file/data are all below 0.4.
There is no schedule file, whence I know when and which shading state is active? Can I generate such a schedule from the Data in HB and use it later in the energy simulation?
How to properly build this kind of control strategy in GH/HB?
Is it possible to control the ECs by temperatur?
Greetings and thanks in advance,
Jakob
