Empty LB Hourly Plot
I am trying to setup a model to get Hourly plot results of energy and thermal comfort. But after the simulation has run, the LB Hourly plot shows and empty result despite me activating the necessary components at HB simulation o
utput.
Hi, if youbset comfort data in outputs true, in the result you should get its parameters. In you image I cannot find what does it mean empty result, could you make it clear ot sent the file?
Hi @pranay_95,
I am having a similar problem with the LB Hourly Plot. I am wondering if the issue which you are referring to is the same as mine and if it has been resolved.
I have been running some Honeybee OSM simulations but the LB Hourly Plots do not show any results.
There is data in results as seen on the screenshots.
Anyone else come across this issue or am I being rather dumb here about something I am doing incorrectly?
You probably just need to set Grasshopper to “Draw shaded preview geometry” , @YogeshGooljar . It’s the little red icon here in the corner:
Duh! My apologies @chris
I am sorry that you had to take time from your busy schedule of all the amazing work on LBT and Pollination to address this. Thank you so much.
