Energy Analysis_Warning
Hi everybody,
I’m encountering a problem with the output of energy analysis made with OpenStudio. Here the warning state:
  1. The simulation has not run correctly because of this severe error:
    ** Severe ** Problem in interior solar distribution calculation (CHKBKS)
What could be the problem/s?
It seems that the results are correct but I still have the warning state.
Thanks in advance.
Best.
Angelo
It means your model has non-convex surfaces or zones. Please check this
To bypass this error, please use Honeybee_Energy Simulation Parameter and use 0 or 1 as an input for solarDistribution_ on the component.
Dear @devang,
Thanks for your fast answer. I would like to fully understand the topic by reading the old post. I’ll do it in the evening. For now, I’ll use the component that you suggested to me.
Again, thank you.
Best.
Angelo
