Hi
I’m trying to find the annual energy offset by the PV panels used, but it shows zero. I’m not sure either if this is a correct setup? As legacy keeps crashing on my Rhino 7 and there are no alternatives in Ladybug/ honeybee
It doesn’t even show results I got (like these)
The PV simulation is quite demanding for computers. Especially with a large amount of solar panels and context geometry. In your script I saw you are running all 4 steps at once. It is better to run the steps one by one. Every step needs input from the previous step.
Thanks @Erikbeeren I added booleans as you suggested to simulate sequentially. All the components also have preview on- still shows wierd results like ‘4 m spacing in between’ and 0 energy offset. Energy_Simulation Photovoltaics_Legacy office.gh (656.2 KB)
The same script worked a month or so ago and showed the general results too. What could be so wrong that it doesn’t display anything, nor does it give predictable results?
