I’m trying to run an energy simulation but I’m getting an error.
Something to do with a shading calc failing. It’s all a bit beyond my skills to understand.
Anyway, see the attached image for more details.
Whether the above analysis is true or not, I have found a workaround. Basically it involves manually using EP v9.0 to run the simulation, outside grasshopper, and then getting Grasshopper to read that result.
Ive just started using the software, but hope it helps. Let me know if you find a better solution
Thanks Ashwin!
This totally works but is a huge pain in the butt. Surely we’re not the only people to have come across this issue. Seems like the HB energy plus simulator is outputting a EPv9.0 file and then requesting an EP9.3 file.
True, its inconvenient… most of the other users are probably using older versions of the programs though, so they may not have run into this. See you around then.
Greetings from Ecuador!, I’m new to hb and was following @chris tutorials but I got stuck in this same problem. I hope there is some fix in this bug soon so beginners like me can keep learning this great tool. Thanks!
Also, thanks a lot @chris for your great tutorials!
Hello @Ashiwin_A, thanks for sharing the solution that worked for you. I tried the same with a file from a tutorial but I got an error when runing the simulation in energy plus v9.0. Would it be possible for you to give it a check to my model, please? I’m absolutely new to hb and this issue is something way beyond my knowledge. Thanks a lot.
1 - Mackey Residence Geometry video 5.gh (586.0 KB)
