i am trying to run Energy plus although i have constructed the zone very well.
Can someone please help? please see attached files.
Regards,
Semaan
00_COOLING LOAD TEST.gh (568 KB)
AT 9AM.3dm (251 KB)
Regards,
Semaan
AT 9AM.3dm (251 KB)
what is the error?
Hi Mustapha,
When I run EP it turns red. Can you please check the attached file.
Actually, I am trying to get the cooling loads for before and after applying a mashrabiya screen that is offset 1.8m from the facade.
I am doing this for a Masters Dissertation. I am also getting an error when plugging the mashrabiya surfaces into the EPcontext input. Eventually the cooling load should go down but it isnt at the moment.
I would really appreciate if you can check it.
regards,
Jalal
