When I run the energy plus simulation I get an error:
- The simulation has failed because of this fatal error:
** Fatal ** Errors occurred on processing input file. Preceding condition(s) cause termination.
the whole comment in panel is: {0;0;0}
0. Current document units is in Meters
- Conversion to Meters will be applied = 1.000
- Current document units is in Meters
- Duplicate surface name! Name is changed to: "srfwall_Dup
- Duplicate surface name! Name is changed to: "srfwall_Dup_Dup
- Duplicate surface name! Name is changed to: "srfwall_Dup_Dup_Dup
- Duplicate surface name! Name is changed to: "srfwall_Dup_Dup_Dup_Dup
- [1 of 8] Writing simulation parameters…
- [2 of 8] Writing context surfaces…
- [3 of 8] Writing geometry…
- [4 of 8] Writing Electric Load Center - Generator specifications …
- [5 of 8] Writing materials and constructions…
- Failed to find in library.
- [6 of 8] Writing schedules…
- [7 of 8] Writing loads and ideal air system…
- [8 of 8] Writing outputs…
… idf file is successfully written to : c:\ladybug\unnamed\EnergyPlus\unnamed.idf - Analysis is running!..
Done! Read below for errors and warnings:
- Program Version,EnergyPlus, Version 8.9.0-eba93e8e1b, YMD=2019.12.30 23:25,
- ** Severe ** Line: 2664 Index: 0 - Error parsing “Material”. Error in following line.
- ** Severe ** ~~~
- ** Severe ** Line: 2664 Index: 5 - “0.7” is not a valid Object Type.
- ** Severe ** [Construction][EXTWALL0] - Missing required property ‘outside_layer’.
- ** Fatal ** Errors occurred on processing input file. Preceding condition(s) cause termination.
- …Summary of Errors that led to program termination:
- … Reference severe error count=4
- … Last severe error=[Construction][EXTWALL0] - Missing required property ‘outside_layer’.
- ************* Warning: Node connection errors not checked - most system input has not been read (see previous warning).
- ************* Fatal error – final processing. Program exited before simulations began. See previous error messages.
- ************* EnergyPlus Warmup Error Summary. During Warmup: 0 Warning; 0 Severe Errors.
- ************* EnergyPlus Sizing Error Summary. During Sizing: 0 Warning; 0 Severe Errors.
- ************* EnergyPlus Terminated–Fatal Error Detected. 0 Warning; 4 Severe Errors; Elapsed Time=00hr 00min 0.19sec
I have no idea if there is something wrong with my epw file path or something else? is it a general error or it indicated a specific problem in my file?
