I’m facing the following errors while trying to run a basic energy simulation:
The simulation has not run correctly because of this severe error:
** Severe ** Weather Simulation requested, but no weather file attached.
** Severe ** GetNextEnvironment: Errors found in getting a new environment
The epw file is attached. What is GetNextEnvironment?
Hi Ashish,
You need to change the file path of Weather file . try to load the weather file a different path, It is better the weather file locate on drive C .
-Omid
It worked!
Thanks Omid Rashidi! This is the first time I’ve encountered these errors.
Hello! I have the same problem. How did you managed to make it work?
Hi Iris
you can try loading the weather file using the component “Open EPW + STAT weather file” and connect a panel with the weather file loaded from “http://www.ladybug.tools/epwmap/”.
i think the problem will be solved
Hi Ashish,
It appears that E+ does not like spaces in the file path names, you epw file must therefore be located in a sequence of fodlers that do not have spaces:
http://www.grasshopper3d.com/group/ladybug/forum/topics/no-weather-…
Nicolas
