Energy simulation failure
Hey guys, I am trying to run a basic energy simulation but I keep on getting the alot of severe and terminating errors
I have E+ version 9.4 and OS version 3.1, HB version 0.0.66 and LB version 0.0.68.
The energy simulation runs through E+ but then it fails, do you think it is due to incompatibility between any of the software versions? Could you please advice, please find below report from E+ and attached is GH file.
Thank you so much.
Rana
energy simulation trial 1_ 20210121.gh (638.1 KB)
        {0;0;0}
  1. Current document units is in Meters
  2. Conversion to Meters will be applied = 1.000
  3. Current document units is in Meters
  4. Conversion to Meters will be applied = 1.000
  5. [1 of 8] Writing simulation parameters…
  6. [2 of 8] No context surfaces…
  7. [3 of 8] Writing geometry…
  8. [4 of 8] Writing Electric Load Center - Generator specifications …
  9. [5 of 8] Writing materials and constructions…
  10. [6 of 8] Writing schedules…
  11. [7 of 8] Writing loads and ideal air system…
  12. [8 of 8] Writing outputs…
  13. … idf file is successfully written to : c:\ladybug\unnamed\EnergyPlus\unnamed.idf
  14. Analysis is running!..
Done! Read below for errors and warnings:
  1. Program Version,EnergyPlus, Version 9.4.0-998c4b761e, YMD=2021.01.12 12:49,
  2. ** Severe ** Line: 892 Index: 2 - Object contains more field values than maximum number of IDD fields and is not extensible.
  3. ** Severe ** Line: 892 Index: 2 - Error parsing “FenestrationSurface:Detailed”. Error in following line.
  4. ** Severe ** ~~~ 2.3215837478637695;
  5. ** Severe ** Line: 893 Index: 19 - “2.3215837478637695” is not a valid Object Type.
  6. ** Severe ** Line: 942 Index: 2 - Object contains more field values than maximum number of IDD fields and is not extensible.
  7. ** Severe ** Line: 942 Index: 2 - Error parsing “FenestrationSurface:Detailed”. Error in following line.
  8. ** Severe ** ~~~ 1.974341630935669;
  9. ** Severe ** Line: 943 Index: 18 - “1.974341630935669” is not a valid Object Type.
  10. ** Severe ** Line: 1017 Index: 2 - Object contains more field values than maximum number of IDD fields and is not extensible.
  11. ** Severe ** Line: 1017 Index: 2 - Error parsing “FenestrationSurface:Detailed”. Error in following line.
  12. ** Severe ** ~~~ 2.448683261871338;
  13. ** Severe ** Line: 1018 Index: 18 - “2.448683261871338” is not a valid Object Type.
  14. ** Severe ** Line: 1132 Index: 2 - Object contains more field values than maximum number of IDD fields and is not extensible.
  15. ** Severe ** Line: 1132 Index: 2 - Error parsing “FenestrationSurface:Detailed”. Error in following line.
  16. ** Severe ** ~~~ 2.3215837478637695;
  17. ** Severe ** Line: 1133 Index: 19 - “2.3215837478637695” is not a valid Object Type.
  18. ** Severe ** Line: 1182 Index: 2 - Object contains more field values than maximum number of IDD fields and is not extensible.
  19. ** Severe ** Line: 1182 Index: 2 - Error parsing “FenestrationSurface:Detailed”. Error in following line.
  20. ** Severe ** ~~~ 1.974341630935669;
  21. ** Severe ** Line: 1183 Index: 18 - “1.974341630935669” is not a valid Object Type.
  22. ** Severe ** Line: 1232 Index: 2 - Object contains more field values than maximum number of IDD fields and is not extensible.
  23. ** Severe ** Line: 1232 Index: 2 - Error parsing “FenestrationSurface:Detailed”. Error in following line.
  24. ** Severe ** ~~~ 1.974341630935669;
  25. ** Severe ** Line: 1233 Index: 18 - “1.974341630935669” is not a valid Object Type.
  26. ** Severe ** Line: 1372 Index: 2 - Object contains more field values than maximum number of IDD fields and is not extensible.
  27. ** Severe ** Line: 1372 Index: 2 - Error parsing “FenestrationSurface:Detailed”. Error in following line.
  28. ** Severe ** ~~~ 2.3215837478637695;
  29. ** Severe ** Line: 1373 Index: 19 - “2.3215837478637695” is not a valid Object Type.
  30. ** Severe ** Line: 1447 Index: 2 - Object contains more field values than maximum number of IDD fields and is not extensible.
  31. ** Severe ** Line: 1447 Index: 2 - Error parsing “FenestrationSurface:Detailed”. Error in following line.
  32. ** Severe ** ~~~ 1.974341630935669;
  33. ** Severe ** Line: 1448 Index: 18 - “1.974341630935669” is not a valid Object Type.
  34. ** Severe ** Line: 1637 Index: 2 - Object contains more field values than maximum number of IDD fields and is not extensible.
  35. ** Severe ** Line: 1637 Index: 2 - Error parsing “FenestrationSurface:Detailed”. Error in following line.
  36. ** Severe ** ~~~ 1.974341630935669;
  37. ** Severe ** Line: 1638 Index: 18 - “1.974341630935669” is not a valid Object Type.
  38. ** Severe ** Line: 1687 Index: 2 - Object contains more field values than maximum number of IDD fields and is not extensible.
  39. ** Severe ** Line: 1687 Index: 2 - Error parsing “FenestrationSurface:Detailed”. Error in following line.
  40. ** Severe ** ~~~ 2.448683261871338;
  41. ** Severe ** Line: 1688 Index: 18 - “2.448683261871338” is not a valid Object Type.
  42. ** Severe ** [RunPeriod][customRun][day_of_week_for_start_day] - “Yes” - Failed to match against any enum values.
  43. ** Severe ** [RunPeriod][customRun][end_day_of_month] - Value type “string” for input “UseWeatherFile” not permitted by ‘type’ constraint.
  44. ** Severe ** [RunPeriod][customRun][end_month] - “28” - Expected number less than or equal to 12.000000
  45. ** Severe ** [RunPeriod][customRun][end_year] - Value type “string” for input “Yes” not permitted by ‘type’ constraint.
  46. ** Severe ** [ShadowCalculation][ShadowCalculation 1][shading_calculation_method] - “AverageOverDaysInFrequency” - Failed to match against any enum values.
  47. ** Severe ** [ShadowCalculation][ShadowCalculation 1][shading_calculation_update_frequency_method] - “30” - Failed to match against any enum values.
  48. ** Warning ** Version: in IDF="=9.3.0" not the same as expected=“9.4”
  49. ** Fatal ** Errors occurred on processing input file. Preceding condition(s) cause termination.
  50. …Summary of Errors that led to program termination:
  51. … Reference severe error count=46
  52. … Last severe error=[ShadowCalculation][ShadowCalculation 1][shading_calculation_update_frequency_method] - “30” - Failed to match against any enum values.
  53. ************* Warning: Node connection errors not checked - most system input has not been read (see previous warning).
  54. ************* Fatal error – final processing. Program exited before simulations began. See previous error messages.
  55. ************* EnergyPlus Warmup Error Summary. During Warmup: 0 Warning; 0 Severe Errors.
  56. ************* EnergyPlus Sizing Error Summary. During Sizing: 0 Warning; 0 Severe Errors.
  57. ************* EnergyPlus Terminated–Fatal Error Detected. 1 Warning; 46 Severe Errors; Elapsed Time=00hr 00min 0.25sec
hi, i have same problem. can you help me?
Unfortunately, I can’t open your file now, but the error report tells you that you created a glazed surface (fenestration type) with more than 4 vertices. Energyplus does not handle these types of surfaces. The solution is to triangularize them but leave a base surface for each triangle. This way the EP engine works fine.
Good work
Massimiliano
