I’ve set up an integrated daylighting and building energy model for a number of shading geometries. I was originally running all the calculations through OpenStudio but I was getting unrealistically low transmitted beam energy values. I went to double check these results by plugging in the same HBZones into EnergyPlus and got much more realistic results.
I’ve spend a lot of time adjusting inputs to see if something was throwing off OpenStudio. I use a lot of custom schedules but none should affect transmitted solar energy. I’ve even tried with no shading devices and still get drastically different results.
I have attached my file if that is helpful for debugging. Am I doing something wrong to throw off the results?
EnergyVsShadingStudy_forDebugging.gh (1.36 MB)
