I am trying to find a way apply Design Flow Rate on a ventilated facade (in my case the outer cladding is a green wall). I understand that the green roof model cannot simply be applied on a vertical facade and that I need to model the cavity, which has a thickness of 10 cm.
For the ventilation I have built volume as a separate zone with a no mass object (OpaqueMatNoMass) between the zone of the appartment / office / … and the green roof / facade.
Now I want to apply the design flow rate on the ventilation (NoMassObject) as described here:
Where can I apply e.g. the BLAST values, windspeed, … in Ladybug / HoneyBee? I tried HB ventilation, but that only has limited possibilites, as I understand.
I assume the “severe” error causes the “fatal” one.
The “SIMPLE_ACH” schedule is missing in the definitions. I would try to add it inside the additional strings you are providing.
Also assume the name of the thermal zone “Zone_vent” exists in the model, right?
