Hello every body
I am trying to rebuild Chris Mackey’s energy plus tutorials in youtube :
However I get a warning in my energyplus node. I use RH 6, GH 1, HB 0.0.63 and LB 0.0.66.
could it be the reason?
Runtime warning :
- The simulation has not run correctly because of this severe error:
** Severe ** checkSubSurfAzTiltNorm: Outward facing angle of subsurface differs more than 90.0 degrees from base surface.
Runtime error :
- The simulation has failed because of this fatal error:
** Fatal ** GetSurfaceData: Errors discovered, program terminates.
Best Regards
Shahrokh Kamyab
