Hi!
We’ve been having issues with the runEnergySimulation component today. The fault seems to not be particular to our PCs, as the fault suddently appeared on both of them, seemingly unrelated to each other. The fault was not there some hours ago, and even when we work with a new and very simple script, the error still appears. Are there others experiencing the same issue?
- The simulation has not run correctly because of this severe error:
** Severe ** ProcessScheduleInput: Schedule:Compact=“ANY NUMBER”, Expecting “Through:” date - The simulation has not run correctly because of this severe error:
** Severe ** ProcessScheduleInput: Schedule:Compact=“ANY NUMBER” has missing days in its schedule pointers - The simulation has failed because of this fatal error:
** Fatal ** ProcessScheduleInput: Preceding Errors cause termination.
