Hi everyone,
I created a HBZone which has glazing on both south and west direction.
I used the EnergyPlus Window Shade Generator component to create shading. But i want shades to be vertical on west direction and horizontal on south direction. How can i create a list item for that?
@feyzas If you want to set two different window shades, you should follow 2 steps:
1.select the wall,create HBsurface and set window ratio to generate windows
2.connect all HBsurface to compose a close volume.
thank you so much @minggangyin . But do you know how can i create list like in the component explanation? (in the attachment). If it is possible it is better for me to just create an input list. I got three south orianted windows and one on the west
