Hi guys, I’m meeting 32 errors when running the RunEnergySimulation component.
Some of the errors are as followed:
- The simulation has not run correctly because of this severe error:
** Severe ** Line: 1436 Index: 2 - Error parsing “FenestrationSurface:Detailed”. Error in following line. - The simulation has not run correctly because of this severe error:
** Severe ** ~~~ 0.0073152477853000164; - The simulation has not run correctly because of this severe error:
** Severe ** Line: 1437 Index: 22 - “0.0073152477853000164” is not a valid Object Type. - The simulation has not run correctly because of this severe error:
** Severe ** Line: 1893 Index: 2 - Error parsing “FenestrationSurface:Detailed”. Error in following line. - The simulation has not run correctly because of this severe error:
** Severe ** ~~~ 0.0034142136573791504; - The simulation has not run correctly because of this severe error:
** Severe ** Line: 1894 Index: 22 - “0.0034142136573791504” is not a valid Object Type. - The simulation has not run correctly because of this severe error:
** Severe ** Line: 2164 Index: 2 - Error parsing “FenestrationSurface:Detailed”. Error in following line. - The simulation has not run correctly because of this severe error:
** Severe ** ~~~ 0.0068416409194469452; - The simulation has not run correctly because of this severe error:
** Severe ** Line: 2165 Index: 22 - “0.0068416409194469452” is not a valid Object Type. - The simulation has not run correctly because of this severe error:
** Severe ** Line: 2497 Index: 2 - Error parsing “FenestrationSurface:Detailed”. Error in following line. - The simulation has not run correctly because of this severe error:
** Severe ** ~~~ 0.0065606599673628807; - The simulation has not run correctly because of this severe error:
** Severe ** Line: 2498 Index: 22 - “0.0065606599673628807” is not a valid Object Type. - The simulation has not run correctly because of this severe error:
** Severe ** Line: 2856 Index: 2 - Error parsing “FenestrationSurface:Detailed”. Error in following line. - The simulation has not run correctly because of this severe error:
** Severe ** Line: 2857 Index: 22 - “0.0065606599673628807” is not a valid Object Type. - The simulation has not run correctly because of this severe error:
** Severe ** Line: 3000 Index: 2 - Error parsing “FenestrationSurface:Detailed”. Error in following line.
The others are not shown.
I’m don’t know what the errors means, can anyone help me with that?Thanks a lot!
Woody
RunEnergySimulation.gh (602.5 KB)
