Hi @AntonelloDiNunzio and all members,
I’ve been using your great “Grasshopper to ENVI-met” plugin to generate ENVI-met INX files from Rhino.
I have a question. It seems to me that the DFEnvimetGrid component does not include the “split lowest Z gridcell into 5 subcells” option that one can activate in SPACES. The only option available is the GH component is the telescoping one.
If I try to edit the grid in SPACES after generating the INX in GH, I have to convert to Concept Design and I loose some facade parameters.
Is there a solution to use the splitting option?
Thanks in advance,
Best
Julien
