Envimet Plugin Grasshopper - Material library node problem
Dear all,
Hope you’re doing great!
I am using Dragonfly legacy with Envimet to run microclimate simulation. However, I have encountered a problem and I would like to ask if you could help me get past it. I am using Envimet 5 and Rhino 7. The problem is with the material library node. Even after the node is grey by adding the material name and filter, all three outputs of the node are empty - there is no material. I do not know if it is the problem with the version or with assigning the correct envimet folder. Your help will be highly appreciated.
Thank you so much!
This version is out of date. You an use the new plugin for envimet.
