Dear @AntonelloDiNunzio,
Thank you for your Envimet Dragonfly plugin. I was using the plugin normally till one time I got this message: ‘envimet4_console.exe’ is not recognized as an internal or external command,
operable program or batch file.
If Envimet is not in default unit ‘C:’ connect installation folder.
However, I have tried to uninstall Envimet 4.4.5 and reinstall it again, but I still get the same messages.
Thanks very much for your work ! I had a question regarding multi objective optimization with your plug in, which I have sent you privately. should I post it here on forum ?
