Hello Community,
As I guess Im not the first one that encounter this situation, Im working on a site in iceland, from which I downloaded the EPW file for the nearest area from the EPW map, but when I plugged it in for some sunpath analysis, this error appeared on the the sunpath component "1. Solution exception:hour must be in 0…23: (6/21@24:25)(m/d@h:m) ", for which I understand it might be a typo on the source file but could find more information in regards of this error
Therefore I started comparing these files with other ones from different areas to find any difference that could lead into this error message, but didn’t find any connection leading into any possible error in the EPW file
Appreciate any help to either correct this file of find a way t work around this issue
Thank you
J
