I am not sure if this is the correct place to report this but this EPW does not seem to be working.
Browser:
GH
Browser:
GH
Hi @ShynnSup,
Some of the EPW links are a bit dodgy. You can usually find the working URL on https://climate.onebuilding.org/
In your case this is the working link:
https://climate.onebuilding.org/WMO_Region_2_Asia/SAU_Saudi_Arabia/TB_Tabuk/SAU_TB_Tabuk.Rgnl.AP.403750_TMYx.zip
Found here:
https://climate.onebuilding.org/WMO_Region_2_Asia/SAU_Saudi_Arabia/index.html#IDTB_Tabuk-
@AntonelloDiNunzio, @mostapha - on GitHub it looks like the two of you are most actively supporting epw map, it seems as though there’s a bug with the onebuilding links missing part of the URL, would you be able to look into it?
Hi @charlie.brooker and @ShynnSup,
Thanks for pointing that out! It seems that some onebuilding links of the epw map are outdated.
I confirm that SAU_TB_Tabuk.Rgnl.AP.403750_TMYx.zip is not in our dataset.
We will update them.
Antonello
new links are available. If you find any other issue just let us know.
Antonello
