Hello everyone, I am a beginner with the ladybug, Can anyone help me to check why the weather data presenting in my rhino is like this. Thanka in advance.
Hoi - since you didn’t post the GH definition file and your screenshot only shows part of the definition, I’m assuming that you have something like what I attach here.
LB_3D_Chart.gh (389.9 KB)
That appears to run fine on Rhino 6 here, so could you please run the Rhino SystemInfo
command and copy-paste the result here?
-wim
Hi,Win
Thanking for you help. I didnt show the definiation because the visialization already went sth wrong at the initial step, as I showed above.
The problem is solved after I reinstall rhino. I was using rhino 6.18, which maybe is not stable. I reinstall a rhino6.8 version, and open the chart you sent to me successfully.
-Shuyu
Hi Shuyu -
I’m not aware of any issues with 6.18 that would cause the chart not to display. The current version is Rhino 6 SR 28. I strongly recommend you to try that version and to let us know how that works.
-wim
