I have used a climate change program to modify an EPW file and generated EPW files for 2050 and 2080 based on the 2018 file. However, when I applied these files to URBANopt, errors occurred, so I tried using the DF Create EPW component to resolve the issue.
When analyzing the results using the LB Import EPW component, the outcomes from the original EPW file (2018) appeared in the upper section of the graph as red, blue, and gray. On the other hand, the results processed through the DF Create EPW component appeared in the lower section of the graph, also as red, blue, and gray.
Why does the climate data appear lower after going through the DF Create EPW component? Additionally, how can I properly apply the EPW files I created to URBANopt?
Thank you for your response. Upon checking, despite having 8,760 rows, an error occurred. As shown in the image, when the file is connected directly, it displays the error message: “1. Solution exception: All of the OpenStudio workflows failed to execute.”
Have you already solved the problem? Acturally, I’ve also meet the same problem when I tried to use my own epw file. If you have some tips to help me, I would really appreciate~
If you read the report in the out part of the URBANopt component, it will have more information about what exactly failed and how to find out more. In particular, the message should tell you to look in the log files of the URBANopt project folder and those will probably explain what is wrong with the EPW file to cause a simulation failure.
Alternatively (or additionally), if you can upload the EPW file here, I will see if I can recreate the issue. If so, there’s probably just a tweak that must be made to the EPW to get it to work.
