I just started to explore ladybug for Dynamo and got stuck at the very first step in the sample file - the epw file won’t read! Why could that be?
Test room.dyn (11.8 KB)
Hi Ashish, Can you post this to the Dynamo forum? I will be happy to check your file there. Make sure to use the tag ladybug.
Thanks Mostapha;
I’ll do that.
