Hello everyone,
I am having trouble simulating with butterfly an “U” shaped hallway of an apartment building which has two inlets and one outlet. I´ve previously ran other simulations successfully even on the same gh file, so I don’t think it is an installation problem. When I ran the simulation I get this message:
- Solution exception:Failed to load values:
Failed to find probes folder folder at C:\Users\EOSIS\butterfly\yumana3\postProcessing\probes
I did several runs trying to simplify the geometry without success, other than running a straight hallway with only one inlet and one outlet.
I would really appreciate if you have any ideas to simulate it. I´m attaching a snapshot of the error and my rhino and gh files.
Thanks in advance
Arturo
TEST_02_0_indoor_airflow.3dm (2.3 MB)
