Error in Annual simulation
Hi everyone,
I’m getting an error while trying to run an HB+ annual simulation.
The error reads in the ‘run simulation battery’ as : 1. Solution exception:Could not CHMOD executable: Access to the path is denied.
Any idea why I could be running into that issue?
I’m also having the same issue on my run radiance analysis node for my annual simulation.
Did you manage to find a solution?
Hi Peter,
I ran rhino as admin and that seemed to help!
Maybe you could try that too
It is most likely a permission issue. Did you try to set the project folder to a different path?
Hello Mostapha, I am facing the same issue, and I tried all the solutions were recommended, but still same error. I wonder if you could help with this issue.
